ampersand
- Sep 2, 2005
- 30
Hello All,
I am a licensed CA structural engineer, and I recently designed a rear addition to a residence in the SF Bay Area. The owner did not provide a geotechnical report. I visited the site, took measurements and photos, and I designed the foundation as a conventional foundation system. The contractor began construction, which included cutting some holes out of the back end of the foundation/slab-on-grade, and unfortunately the GC discovered that it was a PT slab system- and he had cut some of the PT strands.
I am trying to help the owner locate a specialty engineer who can design a fix for the PT slab (I cannot design PT). I will offer my client all the coordination help they need. But I am concerned: Did I act prudently in designing the addition? They will probably have to have another company design a slab fix, and then also re-design the entire addition foundation as some kind of PT system.
It is of course highly uncommon for a residence to have a PT slab system. I did not see (nor did the GC) and "Warning: PT Slab" notations stamped in the garage slab, nor did I see any strand end caps in the foundation. I did not receive any as-built drawings, but it is possible that the as-built drawings are on file at the building department (I did not actually travel to the bldg. department to look this up). I feel bad, because this is the last situation I want a client of mine to be in, but there is only so much an engineer can tell from a visual inspection/walk-through.
My question to you all is simply: Do you think I should have acted differently? I would appreciate any feedback, even if it is critical.
Thank you
Thank you
