Nosa2021
- Oct 21, 2021
- 1
I would really like to know what do you guys usually do/suggest in situations like this.
I have to connect a new RC grade beams (500 mm depth) to existing RC grade beams (450 mm depth). We don't have structure details for the existing grade beams only we know that they contain 5T16mm in top and 3T16 in bottom in support and the opposite in the midlle span.
I will connect RC beams to an existing beams like this: drilling holes in existing beam, then epoxy + rebars.
What I'm wondering is how to make sure that new starter bars will not cut or damage the exist steel bars. Do you guys construction details to show the method statement in support and middle span?
I will appreciate any suggestion, advice, photo or sketch.
Thanks in advance.
Thanks in advance.
