AAAprince
- Sep 7, 2010
- 12
When installing the temporary casing of H-pile, alluvial sand goes into the casing from the casing bottom and then makes the drill bit stuck. Boring cannot be continued. How would you solve the problem?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
