p6g2p6
- Jul 28, 2021
- 36
This question may sound kind of dumb, but this has been confusing me for the last few days.
Here is the scenario. I have a pump system that I've calculated the total pump head for, given a desired flow rate, and I've found a pump that can provide that flow rate at the calculated head. It is crucial that the pump discharges the water at the desired flow rate. What would happen if the actual head of the system is more than what the pump can provide at the given flow rate? Head loss calculations seem to be based off of a lot of approximations, therefore if the calculated head doesn't equal the actual system head, then does that mean that the pump will not provide the desired flow rate?
I hope I didn't make this super confusing.
Thanks in advance.
Thanks in advance.
