Iomcube
Chemical
- Dec 11, 2015
- 184
In this process one of subsystems is : incinerator / superheater / waste heat boiler (aka evaporator) + steam drum & stack
Gas burned is a tail gas from upstream SRU units...
All these equipments can be visualized as follows:
source:
Currently x2 pairs (x1 on superheater tube & x1 on steam drum) of PSVs are located at the red arrow shown & all steam generating equipment [superheater / waste heat boiler (aka evaporator) + steam drum] as under ASME Section I
I have read all the forum entries here & all boils down to this one phrase fired/unfired boiler. Sometimes distinguishing either is clear sometimes it isn't...
Is it possible to reclassify steam equipments to ASME Section VIII. Major reason is to provide isolation to PSVs. Code Case 2254 for Section I is also under review...
source:
