Lifting with round sling 1
Sedlyn
3
I need to perform a structural and buckling analysis for lifting the composite tank (from shell elements). I would like to ask you about the types/possibilities - how to create/define a lifting analysis using round slings. More precisely, how to ideally define the boundary conditions (or 1D connection/springs elements/compensation elements) in the area of contact of the lifted body with the round slings? Or is it necessary to use contact analysis?
Thank you in advance
IMHO it depends from the stiffness of the item and from the type of sling (in the picture the sling is metallic - like a big flat chain coated with rubber)
Flat (width 8 cm) polyester (or nylon) web slings(without any rubber pads, etc.) are considered.
The lifted composite tank has a diameter of 2 meters and a length of 9 meters and weighs approx. 900 kg.
Illustratively something like this:
Do you really need to perform an analysis? What about testing as an alternative?
900 kg ain't much weight.
Unfortunately yes ... because the composite layup of the tank and the maximum level of filtrate inside the vessel during lifting will be determined / optimized based on the analysis.
