GRE PIPE MANIFOLD STRESS CALCULATION
PIPING_DESIGNER
41
Our client ask for a change of carbon steel pipe manifold by a GRE/GRP pipe manifold.
The question is how to support valves to withstand the excess of load on manifold piping system?
Should I support valves from their flanges or from pipe.
GRE PIPE DN: 4 INCHES
Carbon steel valves class 150
Such small valves should probably not need support other than what the pipe provides.
Einstein gave the same test to students every year. When asked why he would do something like that, "Because the answers had changed."
No.
Quite frankly this is not a great design as it is very difficult to properly support these valves and any differential movement in the header will create large forces at the tee connection.
You've got more than an issue trying to support the valves IMHO.
GRE manifolds are not great things to work with.
In my opinion, I think supporting valves from their flanges is more safe for the GRE piping system than supporting from the pipes.
what you think for a DN100 GRE piping system ?
