LOTE
- Sep 9, 2018
- 155
I have referenced AASHTO and AISC for the minimum edge distance and bolt hole spacing, but these seem to only pertain to all the bolt holes receiving a loaded bolt.
What are the spacing requirements if you are placing a single bolt in the closest fitting bolt hole in a cluster of say 8 holes? I am thinking of having two parallel rows of holes that are offset from each other like this image and trying to figure out the minimum spacing. This would be in a hot rolled angle loaded parallel to the two rows of holes.
