NX CAM planar mill
Proizvodnja
44
How to remove in a planar mill these leftovers in corners. I used different machining strategies but they all result the same outcome regarding leftovers more or less.
Planar mill uses boundaries to contain the tool path. It is not "Smart"
This look like a good application of Cavity Mill, which uses the solid bodies to determine the cut volume.
You could still use Cavity Mill to clean up the uncut area by using 3-D In Process Workpiece.
John Joyce
Manufacturing Engineer
NX 2007 Vericut 9.2.2
“Opportunity is missed by most people because it is dressed in overalls and looks like work.” - Thomas Edison
I tried different things, including the rest mill for a corner, and keep getting the error message "the part cannot be cut at any levels".
Also, what does tool overhang mean?
