Cronos_2P
- Jul 1, 2019
- 18
Hello everyone.
My question is the following:
There is a problem if, due to space issues in the pump room, the relief valve discharge pipe and the flow meter outlet pipe in a fire system are buried until they reach the water tank again as shown in the figure? The tank is located at a distance of 8m from the burial point and the height of the tank roof to the floor is 11.5m.
Is there any point in the standard or manual of good practices that prohibits that these pipes that return the flow to the water tank can be buried?
Thanks in advance.
Thanks in advance.
