rollingcloud
Aerospace
I have a chamfered self-lubricated spherical bearing with PTFE liner, the race diameter is about 3.6 inches, the ball inner diameter is about 2.8 inches. Both the race and the ball are made from 17-4PH. It exceeded the sizes listed in MS14103; I am thinking it might fall under ISO 10792 standard? If so, I can try to buy a copy of it. Below is an example for that type of bearing incase my wording is off.
Edit: Looks like it's not under ISO 10792 either, so maybe too big to fit under any standard?
