solidworks piping enable routing
NiiBaa
Dear all,
i try to edit routing at solidworks and option is deactivated. Please advise
Add-in is turned on. It is created at assembly mode
Maybe it has something to do with the Design library of the items that are in the assembly. Do you have the central location to save and load your routing connections?
This tutorial is very extensive maybe it has the solution in it:
Hope this helps,
Scott Baugh, CSWP [pc2]
Mechanical Engineer
Ciholas
"If it's not broke, Don't fix it!"
faq731-376
