Tolerancing grayed out on drawing when adding & modifying hole dimensions
borsht
262
I have a part with a hole wizard hole. On it's respective drawing, I'm trying to add a tolerance to the hole. I click on the "Hole Callout" dimension and under the Tolerance/Precision selections, None, and .125(document) dropdowns. Both are are grayed out, and not drop down-able.
I've also tried adding standard "Smart Dimensions", but they have the same issue on the hole wizard holes. I can however add tolerance to a linear dimension.
Has anyone any advice to fix this issue?
SolidWorks Newbie since 2001
-Currently using SW2021
Inventor Newbie since 2019
-Unfortunately Currently using Inventor22
Ensure your "Hole callout format file" is where the path is also set in your system options. Make sure large assembly mode is turned off
Otherwise, it might be a setting controlled by your admin if you have one.
Hopefully, you can access the SW forum through their new crappy site:
Scott Baugh, CSWP [pc2]
Mechanical Engineer
Ciholas
"If it's not broke, Don't fix it!"
faq731-376
