Determining Young's Modulus (E) for Recompacted Fill using Triaxial and 1-D Consolidation Tests
JHeisenberg
Geotechnical
Nov 30, 2015
17
Any references or personal experience you can share?
1D Consolidation - Using the Modulus of Compressibility (Mv), Constrained Modulus (M), and Poisson's Ratio (v) to determine E.
Triaxial - Using the triaxial stress-strain curves to determine E. How to make sure you are determining E that represents the field conditions you are modeling?
Typical use would be settlement calculations for retaining walls building on new fill.
