SJ8
- Mar 10, 2023
- 4
Hello to everyone,
I'm trying to model a nonlinear spring in ABAQUS.
I followed the ABAQUS guide and I created a simple input file defining one nonlinear spring. I also launched the analysis from the command window and an ODB is generated but when I open the ODB I get this error:
"There is no valid step data available on the database. If the analysis is running, the database must be closed and reopened once the results have been initialized. The requested operation has been cancelled."
Can someone help me?
Thank you in advance
