drcole
- Nov 8, 2022
- 9
i have a part im reverse engineering, its 8mm 304ss, my problem is the part measures 8.3 to 8.5 thick depending on where i take the measurement. is the tolerance for stainless plate that much? if i specify 8mm on my drawing will that be ok?
