Problems when importing parasolid files on MSC Adams Car 1
Miankovelo
Student
Mar 26, 2023
19
I am an engineering student and am currently using MSC Adams to do the dynamic simulation of a bicycle (I am new to the software). I downloaded a model of bicycle in parasolid file from the internet and imported it on Adams View and I could import it without problem, but when I tried to import it on Adams Car the model wouldn't show. I tried several times with other parasolid files but nothing showed. Could someone help me please? Thank you very much in adavance.
Try "Tools- Adams View Interface"
Then return "Tools - Select Mode - ..."
I will try that and let you know how it went. Thank you very much for your help[bigsmile]
Be make sure that to import the objects into the model selected template you need. After display it through menu "View - model". Now in picture only empty model
I see I see. It worked, thank you very very much for your help [thumbsup]
I have been able to open my model in the Adams View interface of Adams car but when I go back to the Standard interface of Adams Car, the model disappear.
