Hi Engineers, Does anyone know o
Franklin Fidelis
Chemical
Apr 4, 2023
1
Hi Engineers,
Does anyone know or have any ideas in specifying flow sequence in Fired Hetaer (with HYSYS EDR model)?
I built a rigorous fired heater model with ASPEN HYSYS, I am unable to add a new stream to the model. When I had the model solved using the first stream in the radiant section, in trying to add a new stream via the Convection Section I'm getting an error message from my EDR saying "The specified flow sequence, through convection banks and/or the fire box is inconsistent"
Thanks in advance for your help.
