Compressed looking text, HOW to fix?
designmr
Hello, and thank you in advance.
I am using a licensed 2018 version of Solidworks. I have a laptop plus two large 32" monitors.
It's a little hassle since text sizes seem to be different on each screen.
The Solidworks explorer text is all bunched up, NOT sure how or what settings I need to modify to be able to even read it. I can read everything on Solidworks fine, but EXPLORER is impossible. And the task I have coming up I really need Explorer.
Also, if I click on anything in Explorer, the text size is even smaller, I will need magnifying glass to read.
(My settings are text 300%, Display resolution is 3840 x 2400 (recommended))
Not sure if the picture I uploaded has the view of the Explorer all bunched up text, it is unreadable.
 https://files.engineering.com/getfile.aspx?folder=be6f6587-78e2-4cda-a2aa-6f9b4529e07c&file=SW_EXPLORER.jpg
I have a 42" Samsung 4K monitor and I only zoom it to 125% @ 3840 x 2160 Res, I am not seeing that issue with my Samsung 4K monitor. I don't run SW full screen either. I don't want my mouse traveling that far. Try reducing the zoom on the monitor; if you cannot see the text, you need to get better glasses. I have to wear a special set of glasses to see my computer screens.
Scott Baugh, CSWP [pc2]
Mechanical Engineer
Ciholas
"If it's not broke, Don't fix it!"
faq731-376
Thank you SBaugh, an IT fixed my problem, seem the laptop and large screen needed different settings...go figure
That would be it. I have 2 other monitors connected and both of those are different than the large 42"
Mechanical Engineer
Ciholas
faq731-376
