tmschrader
- Jun 25, 2002
- 56
Hello
According to several sources ASD and LRFD method will come up with eqivalent beams if DL= 3 x LL. If DL<3 x LL than LRFD will give larger strength sections. Does anyone know if this relation is effected by Ultra high strength ateel with a Yield of 100KSI and ultimate stress that is only slightly more? Like SSAB Strenx 700 (or 100KSI). Since LRFD theory is supposed to be related to the platic design region I would assume a low TS/ YIEld ratio should have a effect on the DL<3 x LL ratio. But do not find anything addressing this.
ref 2 gives a chart that is supposed to show how conservative LRFD is to ASD for different ratios of DL to LL.
Thanks for any insights
Ref 1
REF 2
Ref 1
REF 2
