Wick drain and strip drain connection
Francisco A.
Geotechnical
May 21, 2021
6
Hi forum,
Wanted to know whether somebody could share a connection detail between wick (vertical) drains and strip (horizontal) drains for soil improvement applications. Thanks!
Several options.
The horizontal drains laid on vertical wick drains in the filter material ( sand , gravel..)
Snap from the book SOIL IMPROVEMENT AND GROUND MODIFICATION METHODS..(by PETER G. NICHOLSON )
I cannot give you the formula for success, but I can give you the formula for failure..It is: Try to please everybody.
