Looking for: A pivot assembly which is smooth but also has enough friction to hold 1kg.
CharlieHT
Industrial
GB
Hello all
I'm new to this forum but wondered if anyone could help..
I'm working on a pivot for a bracket which needs to have the following:
- Smooth movement
- Consistent friction to stop it slipping gradually (ideally)
- Not so tight friction wise that it is hard to rotate
- Be able to support around 1kg of weight
- Fit into a hole of a diameter of around 4-10mm
- Ideally be less than 4-6mm in thickness
I have a few approaches:
- Simplest but least reliable(shown in picture) is to have a bolt+washer assembly which once tightened has enough friction to hold it in place.
- The issue with this is over time the bolt has the potential to loosen / grind the washer down
The other option was to find a bearing that has smooth movement but a 'constant' level of friction. I can't find / source this, except this one but this is too expensive.
The final option was to use a nut that holds down a compressed spring to create friction + nylon washer assembly.
I wondered if anyone on here knows of something that could work here?
Or if there are any components that i haven't thought of?
Any help greatly appreciated!!
Thank you!!
Charlie
Have you tried adding a belleville or other spring washer in that bolted joint?
That's probably the best economical choice but I would suggest a wave spring over bellville for a more compact installation.
