I've got an architecturally exposed steel connection that I'm trying to make pretty and I'm considering using 3/4" ASTM F835 flat head screws so that the fastener heads are flush with the steel. The member is a fascia channel that will be continuous past the tips of wide flange cantilevers providing support on the backside of the channel. Bolts will be loaded in shear with a strength level demand of 2 kips / bolt.
The concept is to provide an end plate at the tip of the wide flange that will bolt to the web of the channel, with the bolt heads countersunk into the web. Since the height of the bolt head is the same thickness as the web, I'd be adding a welded shim plate to the backside of the channel so that bolts aren't bearing solely on the sloped surface of the countersunk hole. Holes in the end plate, shim, and web would be standard holes with a nut on the backside of the assembly (no tapped holes).
Does anyone foresee any issues with the proposed connection? I haven't used flat head screws in structural applications before, so not sure if I'm overlooking something. I'd appreciate if anyone would share their thoughts, experience, admonitions, etc.
