Diffuser of a tank type GUN BARREL 3
Inconyma
Existe alguna normativa para el diseño de un distribuidor de un tanque tipo GUN BARREL .
There are some regulations for the design of a distributor of a GUN BARREL type tank.
Thank you so much .... I will warn the others !!!
MJCronin
Sr. Process Engineer
There are no industry or regulatory standards that I know of. I only know one very smart engineer that designes them.
The ultimate goal is to have vertical velocity slow enough that oil droplets or water droplets can settle/rise out. What that is would depend on the droplet size, which is the big question.
For actual diffuser design, there is some information available on diffusers in stratified thermal storage tanks.
