If I have a foundation where the pressure under the foundation is p1, p2, p3 & p4.
Can I consider the volume of the pressures under foundation (the edges are p1, p2, p3 & p4) equal to the vertical load?
If yes (I mean the volume of pressures equal to vertical load), and lets consider the p1 = -5 psi, and p2 = -10 psi, then to proceed with calculation and designing of the foundation, I should consider the p1= 0 and p2 = 0 to proceed with the design?
If I consider p1 = 0 and p2 = 0, the volume of pressure under foundation will not be equal to the vertical load !!!
Can anyone give a help please?
