samsa1
Student
- May 14, 2023
- 2
I have an annulus made of a specific material with known thermal conductivity, this annulus has a specific filled thickness with r(inner) and r(outer), there is hot air flowing inside and this whole annulus is submerged in a water bath at a constant temperature. the annulus will first be immersed in the water bath so that both T(in) and T(out) = T(water), afterward a hot air will enter the annulus at 100 degrees (example),
I'm trying to simulate a temperature distribution on MATLAB for the inner surface temperature of the annulus at a steady state along the length of the annulus.
I'd appreciate the help.
