Cisnerjo
Aerospace
- Nov 17, 2010
- 18
Hello everyone,
I have a problem with a part, it got stuck to the mold tool, there were 17 cycles already performed on it (applying 2 coats of release each time) so it started to build some resin on the surface, so I lightly buffed it down with a scotch brite and re-apply one coat of release but seems it was not enough and it ended up real stuck to the mold. Is there any method or procedure that could help me remove the part from the mold? hot water? apply more release between part and tool ? if able to open a small gap in between? any other advice that you could provide and help me out if possible, based on your experience.
I real appreciate your support on this one its work-related issue.
