ASME BPVC Section VIII Division 2 - Why are the fatigue curves so much lower than other sources?
PaperPapel
I'm sure this is something stupid because this is literally my first time trying to broach BPVC.
But everywhere I look online the endurance limit for 316 steel is roughly 30ksi, maybe as low as 20ksi. In BPVC the curve endurance limit is 15ksi. That's a pretty big difference and it is the only source I can find with such low number.
I'm probably missing some correction factor or something. I see the BPVC is accounting for temp all the way up to 800F, which is no where near my application. I only need ambient in the nominal and absolute worst case maybe 200F.
I also see there is a temp correction equation, 28.3*E3*(Sa/Et), however I can't figure out what "E3" means and unless it way less than 1 this equation is actually going to increase the stress value I take to the charts.
Refer to this link to get better understanding regarding the ASME VIII-2 fatigue curves:
It is important to remember that the ASME curves are not useful for predicting the cycle life of equipment. They are used to specify a permissible design life which includes a large factor of safety, when using the ASME VIII-2 fatigue curves we are not calculating the expected cycle life of the pressure vessel; we are calculating a permissible operating life with a large safety margin
As for "E3" this is the scientific way to write 10^3. 28.3E3 = 28.3X10^3.
Idan said it, ASME is giving you design limits, not failure limits.
