mgoodenough
- May 25, 2023
- 1
Does anyone understand the intent of why stacking studs is mentioned in the ACI 318-19 commentary section R22.6.6.2. The section notes the size factor may not be equal to 1.0 in slabs with stud exceeding a 10in shaft length, but then comments on stacking studs. See figure R22.6.6.2. Is this a work around for the size factor to be 1.0 for vc in slabs with d greater than 10in that have shear reinforcement?
