Linking custom property to configuration specific dimension
FireTruckBerserker
1
Hello all, I've run into a bit of a problem. With linking the dimensions of my multiconfiguration part notes with dimensions. Then I click on a dimension it creates a
"Dim@Feature@Part" path
example:
what i need is a
"Dim@Feature@@Configuration@Part" path.
example:
Does anyone know how to force the path I need to be created?
FireTruckBerserker,
I think you have to type that stuff in manually.
When I mess with configurations and BOM entries, I move very quickly to design tables. Excel is way more powerful than the custom configurations.
You can also investigate the equation editor.
JHG
