Centrifugal compressor running on lighter gas than design
nRGee
Petroleum
Oct 14, 2019
19
Dear All,
What happens when a centrifugal compressor equipped with anti-surge valve is run on lighter gas than design?
(Design MW of gas= 22, Actual MW of gas=13)?
Does it leads to surge?
Thanks and Best regards,
Raghu N
I haven't tried that, but pretty sure that's a yes. Much less density, so it's similar to reducing inlet pressure by half.
What does it say in the Owner's Manual and Vendor Documentation ? ... You can typically find limits to operation there...
Is this a repurposed compressor ? .... How much "lighter" is the new gas ?
More information please ...
What do you mean that it has been lost/discarded by the Plant Staff
MJCronin
Sr. Process Engineer
13/22=59% , implies around 41% lighter. I think that's gotta be off the chart.
To get the same discharge pressure, the compressor will have to go higher up on the head - flow curve with a lighter gas.
How does your ASV work, on discharge pressure only, or on simple differential pressure( discharge - suction), or on mol wt / density compensated flow control?
