NaWin55
- Mar 21, 2020
- 98
Hello all
i need to create a sweep using SweepLinetype and i need to use Axis system directions as Spine
i cant create line in X or Y or Z directions and use them as Spine
i need to select the Axis system and when axis system is selected i need to get the Y direction as spine
as shown in below image
is it possible to get the direction like that using macro
Thank you
Thank you
