IceYogurt
- Jun 16, 2021
- 17
I have read FSSA technical publication (DCG-01) and NFPA 72. However they doesn’t specify the detection placement methods of cross zoning detection in fire suppression system. As per DCG-01, it mentions that “historically, the industry has used an area of coverage per smoke detector of 250 square feet”. It does confuse me whether the smoke detector quantity is to be doubled in the case of CROSS zoning even when I am using 250 square feet to place the smoke detectors.
The same confusion hit me as well in the case that we are using smoke detector (Zone1) and heat detector (Zone2), two different types of detectors, in cross zone detection.
Given that the room (31.6 ft x 15.8 ft x 10 ft H) has smooth ceiling with low air flow, which detector placement method as below is more reasonable and logical in the industry?
A. Place the smoke detector by 250 square feet coverage with adjacent smoke detectors and place heat detectors by 250 square feet coverage with adjacent heat detectors.
B. Place detector (no matter smoke or heat) by 250 square feet coverage with adjacent detectors.
Generally, detector quantity of Method A is always double of Method B as indicated below.
Maybe the two methods are both incorrect. Anyone could help me address the confusion?
