Xprivate
Aerospace
- May 26, 2023
- 47
Hi All , i have two loads for one Boundary condition, for a same BC i have an initial loadcase and after my component is deformed with the initial case, a second load case follows. What is the best way to perform this analysis? i explored some
1)defining two subcases
2)running the first case and extracting the displacements , using this displacement as the initial load to run the second load case
3) or directly giving the first load case as initial conditions and second case in the loads of Boundary conditions card.
what is the best and most accurate way to go? thank you
