Vent Requirement on OH3 Seal Plan 13
az5333
60
Hi fellow engineers. A pump supplier has provided us a vent with API Plan 13 for an API 610 vertical inline OH3 pump. I did not know there was a requirement of a vent. Do we know why it is required and can we blind it off? Thanks.
Suspect this high point from the seal chamber is to allow of escape of flash vapor produced in the sealing liquid as a result of the heat generated at the seal faces. This would be valid for process liquids with bubble point temp lower than say 15-20degC above the max operating temp of the process liquid at minimum normal operating suction pressure.
