abdallah hamdan
During the excavation process for a new building consisting of 6 floors, a footing was found at a level other than all the bases due to the presence of swollen soil that was removed under it, the rock layer has been reached.
the footing for the retaining wall that connects two separate footings is now between two levels. about an 80 cm difference, I'm thinking about making a stepped/sloped footing and saw some details, is there any attachment to design stepped footing or any requirements, or any other suggestions?
thank you for your help
the situation
footing I want to make
the situation
