Yoga Arviansyah
- Mar 31, 2022
- 22
Hi currently, I am in process for designing mechanical components for shiplift and transfer system operation. And, the standard itself (which is code for lifting appliance in a marine environment by LLoyd' Register) state that we should analyze seismic event. What I want to know, is this enough for me only finding base shear forces (from ASCE documents and other data) then analyze it in finite element analysis software (such as ansys) to make sure that the structure is safe? or is there any consideration that I should take on it?
Example of the structure is "trestle" in shiplift
Thank You
Thank You
