When sizing a pump for a glycol system, I understand glycol has a pressure drop correction and well as a capacity correction as a function of the type, % volume glycol, and fluid temperature.
The question is when I give a rep the head(ft) to size a pump, do I give him the corrected pressure drop or the pressure drop as if it were water? The reason why I ask is because their selection software will be able to generate a selection based on the fluid and temperature. In other words, is the head I am giving them Head in Ft h20 or head in ft @ glycol conditions?
