FAT for centrifugal chilled water pump
moideen
AE
"I Participated in a FAT (Factory Acceptance Test) for a centrifugal chilled water pump today. The tester relied on the VFD display reading to determine the RPM and kW of the motor during the test. From what I know, use a calibrated torque meter and tachometer for accuracy, and is it mandatory to get the approval from the consultant? I also noticed that the test data clearly indicates that flow will vary when the discharge valve is partially closed at different heads. Additionally, while checking the shutoff head, I observed that the valve isn't completely closed; around 230 GPM still passes through. I brought this up with the tester, and he mentioned that there's no requirement to fully close the valve. thank you in advance for your valuable response
The problem with the world is that intelligent people are full of doubts, while stupid ones are full of confidence.
-Charles Bukowski-
What's 230 in relation to rated flow?
5% or less just means they're not stressing the pump too much.
What did the test spec say?
Is it an API 610 pump? Or some other code?
Sorry for typing error. The flow is not 230 GPM, but approximately 10% of the rated flow, which equates to around 50 to 60 GPM. I'll be sure to share more details about the test specifications in an upcoming update."
-Charles Bukowski-
@littleinch: the test code is ISO 9906 and HI-GRADE 3B. Thanks
-Charles Bukowski-
It serves no need to test shut-off head,
So what does the test code say?
