Hi all,
If i am planning to have a 75 mm topping above my hollowcore slabs for diaphragm, do i still need to include ties within the hollowcore slab itself? or just provide ties in the topping?
Do i need to breakout the cores and grout with ties as per the picture below? or this would be an overkill? I am thinking moving the ties into the topping would be enough but shouldn't i tie the beams with my hollowcore slab?
