I'm going to design a 3.5' height pedestal per ACI318-11.
It has to support very small axial load.(5 kip axial, 2 kip shear, and 50 kip-ft moment)
I'm curious about minimum longitudinal reinforcement.
1. I have read ACI318-14, and it doesn't tell us to check the minimum flexure reinforcement for the column.
it only shows 1-8%Ag limits for reinforcement.
Do I have to follow ACI318-11 10.5.1, 10.5.2, and 10.5.3 parts for this column?
Or I can only check the 10.9 part?
2. If I want to apply with ACI318-11 10.5.1, 10.5.2 and 10.5.3 minimum reinforcement, how should I arrange the longitudinal reinforcement?
Assume that the minimum reinforcement for X-axis is 6#6 and 4#6 for Y-axis. Can I count the same rebar for another axis?
Is the reinforcement in the left column correct?
