ptr0
- Sep 25, 2023
- 4
The current residential house uses continuous footing/stemming wall for the perimeter, and uses pier and grade beams inside the continuous footing. Can a new attached addition being built on a monolithic concrete slab foundation? Or this new attached addition has to use the same foundation as the existing home? Btw, the soil report says the soil is highly expansive with a Plasticity Index of 27. Any thoughts will be greatly appreciated!
