One thing I'm still struggling to understand is what is the difference between specifying a single cylindrical feature datum for true position tolerance or the same with a flat perpendicular surface used as the secondary datum when no material boundary modifiers are used. Here is an example from the standard:
Here we have true position tolerance zones for the four holes as four cylinders which axes are basically located and parallel to the datum axis A which is the axis of a smallest circumscribed cylinder that is touching the datum feature B. I guess my problem in understanding is right here - why is it important that it is making contact with the datum feature B? If we remove datum B completely from the FCF and have only datum A referenced, wouldn't we end up with exactly the same size and orientation for the tolerance zones for those holes?
