KB4444
- Nov 29, 2021
- 17
My question is with the lateral bracing requirements of a continuous beam under a uniformly distributed load.
For the image below the specific example I have has wall girts/roof purlins spanning (3) columns. The members will have sheeting on the outside that I am treating as a lateral support (attached every 1ft). The issue I have is that the moment of the girt changes from + to -; so does the sheeting only count as lateral torsional bracing for the + moment length of the beam (where the flange it's attached to is in compression)? Or is there a part of the code I'm missing that allows the bracing of one side of a continuous beam to count as laterally braced for the entire length?
I am lookin at this with respect to the Canadian code so CSA - S16.
