ansys dielectric simulation
Cate03
Student
GB
Hi all,
I am new to ansys and I am trying to make a simulation for a dielectric material (zincoxide) to see the output voltage for a fiven applied pressure. when running the following code when I get to /POST1 part and try to display the deformed structure using PLDISP1, it will output the following command "The degree of freedom solution is not available. The PLDISP command is ignored." I dont really know how to fix this. Could someone please help me figure out how to solve this and if there are any other issues in my code? thank you very much !
! Geometry
l = 5e-3 ! beam length, m
w = 5e-3 ! electrode width, m
t = 100e-6 ! thickness, m
!Loading
PRES= 1 !pressure loading, Pa
! Material properties
Y = 140e9 ! Young modulus, Pa
mu=0.358 ! Poisson ratio (nearly incompressible rubber)
eps=8.17 ! electrical permittivity, relative
eps0=8.854e-12 ! free-space permittivity, F/m
/VUP,1,z
/VIEW,1,1,1,1
/PREP7
ET, 1, 5, 3
! == Material parameters
! -- Elastic coefficients, MPa
c11 = 209.71e9
c12 = 121.14e9
c13 = 105.36e9
c33 = 210.9e9
c44 = 42.5e9
c66 = 44.28e9
tb,ANEL,1
tbdata, 1, c11, c12, c13
tbdata, 7, c11, c13
tbdata, 12, c33
tbdata, 16, c66
tbdata, 19, c44
tbdata, 21, c44
! -- Piezoelectric coefficients, pC/um2
e13 = -0.61
e33 = 1.14
e15 = -0.59
tb,PIEZ,1
tbdata, 3, e13
tbdata, 6, e13
tbdata, 9, e33
tbdata,14, e15
tbdata,16, e15
! -- Dielectric constants
emunit,EPZRO,8.854e-6 ! pF/um
mp,PERx,1, 7.57
mp,PERy,1, 7.57
mp,PERz,1, 8.31
! -- model and mesh block
block,-l/2,l/2,-w/2,w/2,0,t
! Set the merging tolerance (adjust as needed)
KETOL = 1.0e-5
SMRTSIZE, 8
vmesh,1
! Structural BC - fix the displacement of bottom face
nsel,r,loc,z,0
d,all,uz,0
nsel,all
! Electrical BC
nsel,s,loc,z,0
cp,1,pres,all
ng=ndnext(0) ! ground node
nsel,all
nsel,s,loc,z,t
cp,2,pres,all
nl=ndnext(0) ! load node
nsel,all
/SOLU
antype,static
cnvtol,f,1,1.e-6
cnvtol,amps,1,1.e-6
cnvtol,volts,1,1.e-6
nsel,all
nsel,s,loc,z,t
sfe, all,6,pres ! APPLY PRESSURE LOAD
solve
fini
/POST1
nsel,all
pldisp,1 ! display deformed/undeformed shape
andscl ! animate deformed/undeformed shape
nsel,s,loc,x,l/2
nd=ndnext(0) ! pick node for display
nsel,r,node,,nd
prnsol,epel ! print strain
prnsol,volt ! print voltage
nsel,all
fini
