AndBre44
- Sep 13, 2019
- 26
Hey all, just looking for some general information/guidance as I look into some information regarding timber piles. I have a client who's building a home near the coast with poor soils from grade to approximately 17 feet below grade, and groundwater present around 10-12ft below grade as well. Typically when I've had sites with poor soils I've always defaulted to using drilled helical piles, however the client came back asking for a recommendation for timber piles as well, and I can't say I have a strong familiarity with them.
I've looked through and read up on the following document from the Timber Piling Council ( ), as well as a couple of scattered papers, but just wanted to put a general inquiry out there to if anyone else may have other suggested resources I could take a look at, or even just some good rule of them design recommendations from those that have done it before. Thank you to anyone who has any insight/suggestions to share on the matter.
Warm Regards,
Andrew
Warm Regards,
Andrew
