Hello forum
Someone having relevant experience - please advise
We are in engineering stage of a tank farm. N-methylaniline, aniline, nitrobenzene, benzene and methanol are stored in nitrogen blanketed low pressure tanks. Preliminary numbers are 4x1'000 m3 tanks, every tank is designed for storing every chemical mentioned.
Q1: Inbreathing is by N2 with O2 <0.5%v. Do we need premixing N2 with air to control O2 in the blanket lets say 5% to provoke inhibitor?
Q2: Nitrobenzene is unstable, tank has a large volume. How should we detect and manage hot spots?
Q3: Recommend drying and inerting method before / after maintenance / inspection. Water displacement is not the best one as we are limited in wastwater capacity. Cold nitrogen is the same is we have no source of liquid nitrogen.
Q4: Should outbreathing be disperced? Or treated? We have an incinerator in process site nearby but engineering contractor refuses to take vapors if those are not separated. We have bad communication, they told that have had an explosion of NB caused by ingress of a some other chemical and do not want having one more. Unlikely they provide more details. They require each vapor line shall be routed directly to burner.
Q5: Should vapor relief be disperced?
Q6: Mobile tanks unloading / loading balacing line - should we provide such?
I have no experience with such chemicals excepting methanol. Any help will be appreciated.
