simonfr
- Apr 11, 2005
- 25
Im trying to understand the text in IEC 80005
The standard considers that the standard rating cables are 6/10(12)kV. Fine all good
But then the standard considers that the Neutral cables are considered to be 1.8/3(3.6)kV.
Now, if we are using say 10kV, the corresponding neutral voltage for the cable doesnt tally, as the phase to neutral voltage will be 5.8kV surely? Therefore the neutral cable insulation capabilities are mismatched?
Greater understanding is much appreciated
![IEC_80005_U0_ptolht.jpg](https://res.cloudinary.com/engineering-com/image/upload/v1700052778/tips/IEC_80005_U0_ptolht.jpg)
