MarkoBg1989
- Nov 20, 2023
- 1
Regards to all!
It is that I bought the said book online by the given author in order to learn CAM skills in CATIA V5 software.
I am writing to you in the hope that you can help me.
Details about the book and related files are below:
The problem arose when I tried to do exercise 3.8.2 (Innengewindedrehen (Ausrichtung: Innen)) on page 226.
When using the Rough Turning command in the Lathe Machining module I do not get the same result as the author. It's about the fact that in my case there is excess material.
I don't know how to correct that mistake, that's why I contacted you.
The author's file of the mentioned exercise is: Drehen_Gewindeschneidoperation_Innen.CATProcess
I contacted the author of the book but without success.
He told me that he had upgraded to a newer generation of 3DExperience software and that he couldn't help me.
In order to better understand my problem, I am sending you my file (26-7-2023-Process1.CATProcess) and a picture showing the mentioned excess material.
I looked through all my settings to fix the error but to no avail.
It would mean a lot to me if you could help me.
If you are not the right address for this question, can you direct me to whom to contact?
Thank in advance.
MR
Thank in advance.
MR
