Existing Joist Data
ArchEng2023
4
Hello everyone. First post here, and thank you in advance.
I am looking for some assistance with some existing open web steel joists. These are on a project circa 1958-1959. The joists in question have a U-shaped chord with flat sections on each side. This is obviously some form of cold formed chord. (photos in links below)
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1700513087/tips/IMG_1575_e28e0j.heic[/url]
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1700513112/tips/IMG_1576_fmuy0o.heic[/url]
So far, I've been able to find something similar from the Structure Magazine series, Link. Based on the table from page 5 and the Figure 21 It looks like it could potentially be Truscon A-S or B-B series joist, but I cannot find any data on these. All that I can locate from Truscon is the O-T series. I also searched for Truscon on this forum with no luck. If anyone has these other joist catalogs or data it would be greatly appreciated!
The best picture I could get of the seat is below. It looks like it is likewise made from a U-shaped piece of steel, I'm guessing just welded to the top U. I didn't even bother looking for tags as these joists are pretty near inaccessible due to the ceiling and insulation. A ceiling tile may have sacrificed itself just to get these photos. [sad]
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1700514765/tips/IMG_1573_pissjn.heic[/url]
Can you post jpg files instead of heic?
Here are the converted images.
That doesn't seem to match the Macomber profile very well.
Based on what I've seen I don't think they are the Macombers. They are an open half circle section, not the pinched V.
Kind of resembles the Sheffield shape, although it could be Trusscon. The Trusscons look like they have a different cross section at the seat though.
I've attached what I have for both companies (probably downloaded from Slide Rule Era way back when). I've also found a lot of old joist catalogs from the Internet Archive.
